Timing cover gasket
Old 11-18-2014, 07:33 AM
N/ALS1's Avatar
Default Timing cover gasket
Is it necessary to replace the timing cover gasket? I read somewhere on the net that I can reuse the valve cover gaskets. I'll replace the water pump gasket, the head gaskets, and the intake manifold gasket as I have the LSXRT intake. Thanks for the help.
Old 11-18-2014, 10:58 AM
11 Second Hall Moniter
AKlowriderZ71's Avatar
As long as they don't tear when removing, and aren't dried out, if they pass inspection then they can be re-used. I put a dab of GMS in the bottom corners to ensure no leak.
chopperloco
07-10-2016 10:45 PM
Denali08
08-09-2015 04:34 PM
MikeGyver
08-09-2015 07:18 AM
Ls3silverado
07-31-2015 04:22 PM
lsxmalibu
07-29-2015 07:08 AM
Quick Reply: Timing cover gasket
