Throttle body question
Old 03-12-2017, 11:03 PM
sinister-one's Avatar
Default Throttle body question
Buying a TBSS intake from a fellow member. This intake takes a 90mm TB.
Would either of these TB's be a good choice ?
92mm Throttle Body GM Gen III Ls1 Ls2 Ls6 Ls3 Ls Ls7 Sx Ls 4 Cnc Bolt Cable | eBay
92MM GM GEN III LS1 LS2 LS6 Throttle Body Ls3 Ls Ls7 Sx Ls 4 Bolt Cable | eBay
Thanks in advance for your input.
Old 03-13-2017, 07:19 AM
03sierraslt's Avatar
I would be Leary of no name throttlebodys, if they don't seal right or the IAC circuit doesn't work properly you will have a tuning nightmare. I suppose all you could do is try.
Old 03-13-2017, 07:47 AM
So the answer would be no....
Old 03-14-2017, 09:19 AM
How about these throttle bodies ??
Holley 860001 Sniper EFI 92MM Throttle Body LS Engine, Silver, Cable Drive
http://www.texas-speed.com/p-5805-ho...ble-drive.aspx
Old 03-14-2017, 10:08 AM
Drspencer's Avatar
Any of the name branded stuff is good. I had a Professional Products throttle body on a Ford 5.0 and it was suckin' in air from the throttle shaft bushing. Never got it to idle right. Sounded cool when I let of the gas. Whistled like a blow off valve!!
Old 03-14-2017, 10:33 AM
Any of the Holleys should be fine.
Old 03-14-2017, 10:42 AM
Looks like I'll be ordering one !
