Starter for a 4l80 swap in SSS
Hello guys and gals need some help with a part number for a starter for my lq9 I swap a 4l80 in to replace my 65 and I went to prime my motor today and the starter wouldnt reach my flex plate bc of the spacer they told me I needed to go in between my crank and flex plate. Do I need the spacer? And if so does someone have a part number for the starter I need? Thanks
I did this same swap on my SS. What flex plate, stock or aftermarket? I used the tci flex plate and I got a 4l80 converter from precision industries.
How far did you pull your converter out of the transmission pump when bolting it up to the flex plate?
