Stall recommendation?
Just put the Comp XR265HR-14 camshaft in my 4.8 along with fresh 862 heads. The stock converter seems ok with it but I'm guessing a slightly higher than stock stall would help it some. Any recommendations? It has factory 245/75-R16 and 3.73 gears. TIA
I know its a small cam... but its a small motor. That 4.8 will want all of a 3200 converter.
If you want to do this on a budget I would do a 278mm 3200. If youre willing to step up a 9.5" billet thats a tad looser will perform a lot better, but drive a lot looser on the street.
I spoke to FTI and they recommended a 2800 stall with my combo mainly because I still tow a boat with it. I just installed a Flex-a-lite direct bolt in cooler also.
