Spun bearing after procharger install
Old 04-03-2015, 04:33 PM
  #21
Byrdman11's Avatar
The head may have a few bend in it but you can fix them.
Old 04-06-2015, 09:48 AM
  #22
HemiRamOn22s's Avatar
Originally Posted by Delaware ss
Not blaming anyone, things happen with mods I understand that completely...
Just wanna know what's wrong and why so it doesn't happen again when I rebuild it. If it was just the tune that's fine I can live with that I had an appointment for a dyno tune and yes I probably should of just waited to drive it until after that I use see a lot of people using the bb tune and it working fine. I do lap percolate all the input. I'm pulling the head next week so I will see then how much I gotta do to fix it.
We will have it back on the road in no time!
Old 04-06-2015, 12:43 PM
  #23
Tootall's Avatar
Before and after - YouTube
Before and after video
sounds like a trashed lifter or bent push rod
Old 04-06-2015, 09:52 PM
  #24
Delaware ss's Avatar
Pulled both heads tonight, Cylinder 6 piston is wobbly and was hitting head lightly. Guesing the rod is bent but going to pull the pan tomorrow. I am thinking best option is just getting all new rods and pistons. How bad is the install whithout pulling the engine? Ill go ahead and stud them as well as ls9 gaskets and new injectors while I'm at it
Old 04-07-2015, 06:33 AM
  #25
Byrdman11's Avatar
Now you talkin! The forged rods and Pistons will put you in business. I made 900rwhp on this type of short block. But you will need to pull engine and balance assembly.
Old 04-07-2015, 01:31 PM
  #26
Formerly ScreamingL
George C....'s Avatar
Whatever you do as for fixing motor make sure you get yourself a good tune from a tuner who is used to dealing with a lot of power.
Cause a stout motor can fail in the hands of a non experience tuner
Old 04-07-2015, 04:10 PM
  #27
Andrew at complete street performance in west Chester pa is who I was going to use. He tuned my camaro and I've watched him tune a lot of much higher HP cars while at his shop
Old 04-10-2015, 08:40 AM
  #28
gagliano7's Avatar
You will have no problem with Andrews tune. He is very good. Maybe there was to much timing in the tune or your motor was getting ready to go anyways.
ARC
57
02-21-2022 10:54 AM
Jake75
08-05-2015 01:26 PM
Dezert1500
07-30-2015 02:51 PM
iregret
07-27-2015 10:31 PM
Quick Reply: Spun bearing after procharger install
