Speed Engineering True Dual Exhaust Prototype..
Old 08-20-2016, 06:32 PM
  #571
Wolftrk99's Avatar
Most exhaust systems i have seen are actually able to be setup either rear or side exit, depending on orientation of the tailpipe itself...
Old 08-21-2016, 07:45 AM
  #572
MidnightExpress99's Avatar
Originally Posted by Speed Engineering
Yes, sir. We prototyped it a few months ago. We're waiting on it to come back for fitment verification. If everything fits correctly the first time we should have a batch probably by the end of the year.
Thanks
Sean
Sean,
If we already have the current design, (waiting on my kit to ship when next batch comes in) would it be possible to order just the tail pipes for over axle based on the prototype design?
Old 08-22-2016, 10:44 AM
  #573
Former Vendor
Speed Engineering's Avatar
The rear exit kit is designed with a little bit larger mufflers. Still a blow through design, both 3" with dual pipes exiting around the factory passenger side rear. We will sell the rear kit with mufflers individually yes for those wanting to convert there dump system to a quieter rear exit system.
Thanks
Sean
Old 08-22-2016, 11:37 AM
  #574
gunter96ws6's Avatar
Thanks
Sean
Is it set up to exit out the back under the rear bumper or 2 pipes out the passenger side behind they pass rear tire?
Old 08-22-2016, 04:13 PM
  #575
Former Vendor
Passenger side rear tire.
Thanks
Sean
Old 08-23-2016, 12:39 PM
  #576
10 Second Club
Thanks
Sean
You'll sell the hell out of that setup. I spent two days last month with a chop saw and a box full of mandrel bends. I would have preferred a prefabbed system that fit without too much trimming.
Old 08-23-2016, 01:21 PM
  #577
mvrk10256's Avatar
Ya. I am in for a long system and a set of LT once the ORY pipe fits a 6 speed.
Old 08-30-2016, 07:19 PM
  #578
fix-it man's Avatar
Still pretty interested in this exhaust setup as my truck needs to be redone shortly.
What is the estimated cost and decibel level for an over the axle rear exit system?
Old 08-31-2016, 03:23 AM
  #579
eray92's Avatar
Will the over the axle kit be tucked up pretty well? My stock exhaust hit the axle after I lowered it 4/7(nbs ext cab)
Old 08-31-2016, 07:33 PM
  #580
Tig
Tig's Avatar
That's a good question. By the time I'm done, I'll be at 4/6.
This is for an 07 Tahoe.
Has it been confirmed that this set up will work for SUVs?
I don't mind modifying it if I have to.
Quick Reply: Speed Engineering True Dual Exhaust Prototype..
