Speed Engineering True Dual Exhaust Prototype..
#491
Biggest difference in tahoe and rcsb is the spring set up in the rear, the kit dumping before the rear axle shoukd be fine... Food for thought, gm used the same exhaust setup on the silverado ss and denali... Extension pipe and tailpipes are biggest difference....
#492
Tried to install mine earlier on my 03 single cab 2wd 4L60e and no luck. I'm running stainless works longtubes and having a couple issues. First, is that the connections are the same size so takes a little finessing there. Second, the pipe is hitting the side of trans and not letting it sit in straight therefore throwing off the fitment of the driver side collector and new exhaust s piece. Didn't make it any further than this but will let you know of any new updates as they come available. Sucks because I've been waiting since I got the exhaust when it came out and now everythings not cooperating all at one time on me. Any helpful insight is appreciated.
#495
They fit just fine with calspeed lt's. If your truck is lowered(6/9), they are loud as hell. My dumps are only 8" off the ground so that is the reason. Also Vibrant ultra quiet resonators do dull it in the cab, and don't really change the tone outside much.
#496
Does NOT play well with ARH headers. But I made it work. Had to cut my ARH mid pipes to make the connection to the headers instead of using the supplied pipes that connect to the new x-pipe.
Observations. The supplied clamps pissed me off more than anything else. And while trying to really cinch them down, the threads would strip. As opened up as I could make them without the nut coming off, they would not slide in place. I had to hammer them into the flared part of the pipe. They really suck.
This exhaust is louder than I expected. I had 1-7/8" headers, no cats -> into the stock exhaust. It was decent but I wanted louder. Holy **** it's loud now. I'm considering sound matting the cab under the carpet. It's loud.
#497
What mods have you done?
#500
But you have a PM
