Speed Engineering True Dual Exhaust Prototype..
#642
12 Second Club
Headers are noisy, simple as that. They are not built from thick cast iron like a factory manifold, headers use 16 or 14 gauge steel so they are going to be noisy.
Personally I love the sound of a machine working up front and the noise it makes coming out back!
Chad
Chad
#643
Headers are noisy wrapping them will help some though... i havent had a chance to install my headers yet, but my cast manifolds have a leak somewhere on initial startup but once it warms up it goes away... sadly two different sets of manifolds and cat pipes and the noise is still there.... i can get it to go away for a couple of days but will come back, hopefully my headers finally getting installed will finally get rid of it....
#645
What's the best way to make the headers clear? They were fine with my 6.0, but I'm in the middle of a 6.2 swap and the were touching the frame now with new motor mounts. I clearanced them a little with a rubber mallet, not sure with will be enough though with motor rock.
#646
#647
#648
So, they hit with the new engine but not with the old? Is there more clearance on one side vs the other? How much are they hitting? All things being equal, there should be no difference between the old engine and the new engine! Unless with the new mounts The engine slightly shifted to one side or the other?!
#649
My under hood noise is minimal compared to at drivers door
I have Speed Engineering 1-7/8 Long tubes and under hood is not loud at all, standing outside the driver door is much louder. I have a minor leak at the y pipe center junction (elbow tube). I have been dealing with it for now, I plan on swapping converters and doing a vette servo so tranny is coming out again. I also just purchased Speed Engineering "true dual" Kit. I will post pics upon completion and also report any noise issue. Side note I did purchase 3" clamps to use instead of supplied hardware.
#650
They hit bad enough to barely seat if they even do. I'm more worried about motor movement and how much they will. I noticed the new mounts are a little softer than my previous ones. I wrapped them with header wrap so I will have to test fithe them again. I clearanced them a little so hopefully its enough
