Speartech LS2/6L80E swap!
#101
10 Second Truck Club
On the 58x motors its pretty easy as i have one in my 07 RCSB in my sig but the older ones are a little harder. Some people have used a complete dropout with the new pcm and still have to use the factory pcm to run gauges. Probobly what keeps peolpe from doing this.
#103
i have a complete dropout from a 2010 ss Camaro. including accessories harness ecm 6l80e... whats the best way to contact speartech? really trying to get this swap done but need to find everything needed for the swap.
#104
Registered User
Hello Sir. I was reading your post about this swap that you performed. I also have a 2001 swb truck but with a 5.3. I want to swap it to the 6.2 but still use the original transmission. Is this possible to do? Could you explain to me what all will be needed to convert it? I saw where you made a harness so I know I'll need that part but anything else would be appreciated. I tried to send a pm but your box is full.
#105
Knock sensor extension harness, can sensor harness extension, 58x to 24x conversion(either changing the reluctor on the crank or the electronic adaptor) then there is fuel injector adaptors, return to returnless style fuel system... 6.2L is gen 4 and can be run off the factory harness and pcm, with adaptors... Other option is if you dont have the engine already, get ahold pf a gen 3 short block and run the l92(823 casting) heads...
#106
I used a Corvette fuel filter to convert to returnless fuel system.
If I recall correctly GM didn't start DBW on the trucks until 2003 so you'll need a cable operated throttle body if your truck isn't so equipped.
Everything else should be a straightforward swap. I used my original motor mounts because the NNBS ones were too tall to allow the intake to clear my cowl.
#107
#110
Custm2500's Rude Friend
FYI Some 2500/3500 applications continued to use the cable TB in 2003 as well.
