Spark plug gap, 2002 5.3 litre Chevy? - PerformanceTrucks.net Forums
Thread Tools Search this Thread
Old 08-11-2005, 08:16 AM   #1
JimS's Avatar
Default Spark plug gap, 2002 5.3 litre Chevy?
I have a 2002 5.3 litre Chevy. The book says the spark plug gap is to be .060 but the guy at the Chevy garage said he thought that there was a bulliten out that the gap should be .045.
What the truth?
JimS is offline   Reply With Quote
Old 08-11-2005, 10:03 AM   #2
chevyerett's Avatar
I gap my ngk's at .060". Runs smooth. As long as it keeps running smooth I'm gonna stick with .060".
chevyerett is offline   Reply With Quote
Old 08-11-2005, 08:03 PM   #3
PT's Slowest Truck
budhayes3's Avatar
It all depends which plugs you're using, and if you're N/A or F/I. Stock gap for the platinums is .060. The Delco Iridiums should be pre-gapped at .045. I keep my NGK TR55's at .055 which is straight out of the box. Alot of FI guys run NGK TR6's at .030 to .035 I believe.
budhayes3 is offline   Reply With Quote
Old 08-11-2005, 09:34 PM   #4
Yup I just installed the TR55's tonight and they are pre-gapped at .055 which is where I left them. Runs pretty dam good too!
Zick is offline   Reply With Quote
Old 08-11-2005, 11:03 PM   #5
Cool
NGK TR55 are pre gapped at .059" according to the NGK part # key. The first 5 is the heat range and the second five is the gap. This series of plugs have a heat rating of 4 (hot) to 6 (cold) so 5 is in the middle and gaps of None = .039" ( ex TR6 ); 5 = .059" and 0 = .080".I noticed the TR6s I installed were a very loose .035" when I installed them but they were close so I left them. I tried adjusting one but it was a real pain for the small difference so I left the rest and adjusted the other one back to the factory setting.
Mort is offline   Reply With Quote
Old 08-11-2005, 11:16 PM   #6
bud8fan's Avatar
i pulled my stockers out today to get ready for the radix and just for the hell of it i checked them... at 5000 miles....35 is what i got
bud8fan is offline   Reply With Quote
Old 08-12-2005, 07:38 AM   #7
JimS's Avatar
I'm running AC's just like the stock plugs but with the Radix which is being installed now. Nelson tune to come after the Radix is up and running. Will Allen recommend a different plug maybe?
Old 08-12-2005, 08:16 AM   #8
bud8fan's Avatar
ngk tr6 at 35.spark will blow out on stockers.....
Old 08-12-2005, 10:50 AM   #9
Cool
Quote:
I believe Allen will recommend the NGK TR6 gapped at .035 along with most other people. I see that BigTex is using the Iridium IX version of the NGK and seems to be having good luck with them.
Old 08-12-2005, 11:07 AM   #10
Cool
Quote:
The stockers in the Avalanche are gapped at .035 from the factory for '05 ???? That seems weird because the stock gap is .060 on all the Silverados for '03 from the 4300 right up to the 8100 according to my Owner's Manual. Something new?
Thread Thread Starter Forum Replies Last Post
P0304 flashing SES what to check next rojeho GMT 800 & Older GM General Discussion 4 08-08-2015 08:20 PM
03 ECSB Custom T56 Swap Ketis Trucks and SUV Classifieds 6 07-23-2015 01:37 PM
Chasing PO300 Misfire-Log File Attached wheeliE-maxx Tuning, Diagnostics, Electronics, and Wiring 10 07-19-2015 06:37 PM
hesitation at full throttle, normal at partial throttle bsgiffor GMT 800 & Older GM General Discussion 1 07-19-2015 12:14 PM
spark plugs sTNT971 FORCED INDUCTION 6 07-16-2015 01:39 PM
Tags
02, 2000, 2005, 53, 60, 60v, autolite, chevy, gap, gm, gmc, litre, lt, plug, spark
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
