should i send these headers back?
#31
in theory it should only move the collector out. i'm hoping for roughly 1/8 at the front header flange bolt and 3/8 at the rear header flange bolt. I used small blocks of wood behind the flange to simulate a 2nd decked flange and the collector fits nicely tucked up under the car.
#33
I have a gauge for that
Depends how aggressive your belt is I suppose. A mill would certainly be the best bet.
Start with a 1/2" flange. Make a mark 3/8" from the bottom on one end, and 1/8" from the bottom on the other end, then draw a straight line connecting the two points. Angle the piece so this line is parallel to the cutting surface and press down until the line is at the belt or cutter.
#36
Got any buddy's with a Bridgeport mill? I would just tack weld it onto another block so it was flat, setup the block offset on the table and mill it down. Prob take 1/2 hour. Then I would weld the flanges together, clamp the header to the table, and use an end mill to recess the holes flat.
