should i send these headers back?
#21
Nice. Now you just need to order up a custom flange. If you can't order one than I'm sure a machine shop could cut one down. Might need to make some tappered washers also so the bolt sit flat on the flange.
#24
I guess this is not as easy as I originally thought. Talked to 2 machine shops about angle decking the header flanges down and they aren't interested. ARH hasn't replied to my last e-mail in 3 days. finally called my local head porter and he is wanting to call me back later today. fingers crossed that I can make this happen without breaking the bank.
#25
Got any buddy's with a Bridgeport mill? I would just tack weld it onto another block so it was flat, setup the block offset on the table and mill it down. Prob take 1/2 hour. Then I would weld the flanges together, clamp the header to the table, and use an end mill to recess the holes flat.
