Rotating assembly for 408 stroker
Hey guys, this is the first engine I'll be building from scratch as a short block (lq9). I'm trying to find the best rotating assembly and am wondering if there is a kit that is just the best of the best, or if I would be better off getting a crankshaft from one company, pistons from another, etc. and piecing together everything but by bit? I know I want a forged assembly, but other than that I am still trying to figure everything out. Any help would be much appreciated!
Are you saying I should stay away from TSP? I probably won't be buying a kit from them. Even if it does end up being slightly more expensive, I'll most likely end up piecing together my own bottom end. The top end is what I'm having trouble really deciding on now.. haha
I plan on running wither 4.88 or 5.13 gears if that makes any difference.
8 Second Truck Club
I was just saying if you want the best of the best the crankshaft alone will cost more than the short block that you need. I'm talking billet center counterweighted bad mother ****** probably over 2000 just for the crank.
I have no opinion about TX speed other than it was contradictory to what you were asking.
Cylinder head flexing is typically the first issue that pops up. You'll push the head gaskets out of it before you make enough power to break anything in the bottom end.
....although, those crazy aussie ******* are pushing a ton of boost into these things using that special head gasket. Enough so that my above comments could likely be wrong. I just don't have experience with them personally and internet tales make fools chase tails.
