Roller Lifter Wheel Diameter
Ordering a custom cam from cam motion. Does anyone know the roller lifter wheel diameter in a 2012 6.0? Also wondering what length pushrods to go with the stock valve train
Its a stock lifter just like any other LS motor from the factory. Just tell them you need a cam for an LS motor. That question has never been asked to me by any cam company i've called.
An only true way to dial in a pushrod is to use the pushrod tool and a dial indicator. Which most cam gurus can dial that in with ease by simple math. Almost every new motor without head work runs a 7.425" pushrod. You wont have any issues running a 7.4" either it'd just be less preload on the lifter
Damn keniff youre on top of everything! I couldnt get the answer through email at first but they finally said stock would be .700. And i guess ill stick with 7.425 pushrods. Thanks!
