relocate IAT sensor?
Old 06-14-2009, 11:03 PM
charcold-bowtie's Avatar
yes he did. that looks similar to the msd-2320 sensor. It can be bought from summit.
Old 06-14-2009, 11:14 PM
Resident Retard
BlackGMC's Avatar
I thought that the IAT sensor was in the MAF...did you get a different sensor and remove and re-route the wires Corey?
The stock one is in the MAF, but it is really slow reacting... I got the one colton mentioned above and cut the wires (brown and black) on my maf and wired it into the new sensor... The sensor is only like $15-20.. Depending on how your tune is setup your probably pulling alot of timing due to IAT temps, those IAT temps with the stock maf are not accurate at all since it heat soaks and reacts really slow....
Old 06-15-2009, 11:13 AM
PT's Slowest Truck
budhayes3's Avatar
That's very good to know, looks like a cheap mod that equals more acurate PCM correction and more power, surprised that I haven't heard more about this mod
Old 06-15-2009, 03:12 PM
Raffman's Avatar
there was a lot of buzz a year or so ago on this mod but haven't seen much til now. If your MAF is maxed out it isn't going to get you much.
Old 06-15-2009, 03:28 PM
Resident Retard
BlackGMC's Avatar
How does the MAF being maxed out even pertain to relocating your IAT sensor?
Old 06-15-2009, 03:39 PM
shakesvho's Avatar
I remember reading about this and forgot about it, thanks for posting it back up and the info corey
-tommy
Old 06-15-2009, 03:45 PM
traveling mod
andrew383's Avatar
where is everybody getting there sensors at?i can get the breakout harness and the sensor for $60
Old 06-15-2009, 03:52 PM
silveradokidd_4518's Avatar
i have never noticed this on your truck before Corey... i might have to do this to mine...
Old 06-15-2009, 03:55 PM
sonoma43's Avatar
Jegs carries MSD's IAT sensor...its like 25$ or less
Old 06-15-2009, 06:41 PM
Raffman's Avatar
the guys using meth were moving the IAT sensors to the intake and fooling the computer that the air was cooler and enriching and advancing timing but in high hp the maf might already be near the limits..........or so the theory.
Quick Reply: relocate IAT sensor?
