Question on LS7 lifter preload and Pushrod length.
#22
That is the way Comp and other have told me to do it. Are you referring to putting in the length checker at 0 turns, tightening down the rocker arm, then turning the pushrod checker until it reaches 0 lash at the rocker, remove the rocker arm, figure out the length of the checker, then add the preload to it?
#25
put the lifter on the base of the cam
torque the rocker down
find zero lash with adjustable pushrod
measure pushrod after finding zero lash
add desired pre-load
why make this harder than it should be if you already have the tools to do the job correctly?
#28
I was doing the method I mentioned because, like I said, Comp and other have told me to do it that way. As well as watching countless youtube videos. Measure preload by turns. So I was going based off of that. Not that I am fixated on that, just doing it the way I was told would be best.
But either way, I got roughly the same results after adjusting pushrod length to zero lash with rockers torqued down, then adding preload.
Also, the ones who said I was doing it the wrong way, you never provided another way to do it. You just said, "why are you making this difficult and doing it that way". If you would of provided another way then I would of done it that way. Also, I knew about counting the turns on the pushrod checker until you have reached 0 lash on the rockers, (which have been torqued down) then removing the rockers and measuring the pushrod checker and adding the desired preload. But COMP cams told me not to do it that way, and since I have never really done this before, it did it the way they told me and watched the video they emailed me.
#29
I finally watched the video that you posted. I like their method of using a dial indicator to measure how much torquing the rockers, after finding zero lash, preloads the lifter using a stock pushrod. There isn't much room for your fingers to adjust an adjustable pushrod, and the dial indicator seems easier. It seems to me that their idea of counting turns of the bolt between zero lash and 22 ft/lbs is just to give you a general idea if you will need a longer or shorter pushrod than the one you are using to check.
