Question about GM exhaust manifold gaskets when using stock cast iron manifolds
Hey all, when I tore my truck apart I noticed that the factory 5.3L exhaust gaskets were possibly a tad bit too small. Part of the gasket circumference has carbon soot in areas that indicate the gasket is protruding into the port area. I would like to use LS3 gaskets part # 12617944 which I have laying around. These are slightly larger than the ports on the manifolds. Anyone see an issue with this? Normally I would not think twice about using them on an n/a build but on a turbo setup I thought I would make sure. The heads being used are unported 862 castings.
Registered User
I wouldn't see a problem using them as long as they have decent contact area with the flange. Ever thought about port matching the heads and manifolds to accommodate the bigger ls3 ports?
ARC
57
02-21-2022 10:54 AM
Gadgetized
07-07-2015 04:40 PM
