Pushing oil.
Pushing oil.
Still have a slight oil leak from the back of the valve covers, I think. Have a few drops at the back/bottom of the pan after a couple of runs. Push-in oil fill cap on the LSX valve covers also wants to blow out, so I had to make a bracket to hold it down. Diptstick pushes out a little, but the heater hoses hold it in. Running about 18.5 psi of boost. I have both valve covers vented to a breather tank, which only collects water.
What else can I do?
What else can I do?
^^^^ what he said. I think it will help. And if enough vacuum is pulled it can help a lil on ur time. It did on my friends camaro. (less pressure under the pistons will allow easier movement in the crank case.
