power steering pump pulley - PerformanceTrucks.net Forums
Thread Tools Search this Thread
Old 02-10-2010, 08:19 PM   #1
Question power steering pump pulley
I bought a used power steering pump from a salvage yard and the pulley came with the pump but wasn't on the shaft. Inside the shaft is threaded but I can't tell what size bolt to use and was wondering if anyone knew what the thread size is?
Formula_LT1 is offline   Reply With Quote
Old 02-10-2010, 10:01 PM   #2
MikeGyver's Avatar
MikeGyver is online now   Reply With Quote
Old 02-11-2010, 02:10 AM   #3
8 Second Truck Club
Blown06's Avatar
If your asking this question cause you need to get the pulley off, I would suggest you go to an autoparts store and rent a power steering pulley removal/installation tool. Its usually free and will save you a lot of trouble.
Blown06 is offline   Reply With Quote
Old 02-11-2010, 07:01 AM   #4
Quote:
No, I need to put one back on.
Old 02-11-2010, 03:56 PM   #5
MikeGyver's Avatar
Then you need an installation tool. If you try it with just a bolt and washers, the threads will pull out of the pump shaft.
The tool has a bearing that is pushed by a fine thread pusher thing.
Old 02-13-2010, 01:34 PM   #6
Is this some kind of special tool that is going to be hard to find, or will a regular pulley puller work?
Old 02-13-2010, 09:04 PM   #7
Mrgoodwrench3's Avatar
You need to use the installation tool. Don't use a bolt in the shaft. It puts too much stress on the threads, you will ruin the new pump.
Mrgoodwrench3 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
FS: Duramax swapped RCSB 1500 4x4 thunder550 Trucks and SUV Classifieds 9 10-08-2015 05:53 PM
2012 I/C Turbo 5.3 VVT Chevy CC LT Ls3silverado Trucks and SUV Classifieds 0 07-31-2015 05:22 PM
05 trailblazer power steering leak 1320Chicken GM Drivetrain & Suspension 2 07-14-2015 11:58 PM
Steering box vs Power Steering Pump, Help Diagnose a Whine lxcoupe GM Drivetrain & Suspension 1 07-08-2015 06:49 AM
Tags
2000, 53, bolt, chevy, power, pulley, pump, putting, removal, shaft, silverado, size, steering, thread, tool
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
