Ported 799 Users?
Ported 799 Users?
I've found it interesting in the 6+ hours I've tried searching for information on ported 799 heads, I have yet to see someone who had existing 799's they took off to get ported. Seems like all I see is ls1 guys buying 5.3 heads and making obvious power.
Has anyone takin their 799's off and can vouche for a power increase that's worth $1300? I'm about to just swing for the fences and by a set of promaxx's with 2.08 valves and cross my fingers....
Thanks!
Thanks!
Avery@texas-speed.com
The 799 & 243 are basically the same head. People port the 243 ( LS6 ) heads all the time.
Depending upon what 5.3 you have you may want to mill them some to gain a bit in compression. Once ported the head will flow very well. On a DD 5.3 truck I wouldnt go too wild on valve size! Also larger valves can cause some PTV clearance issues, and/or shrouding in the small 5.3 bore.
See below for some flow charts:
LS6 Stock ( 2.00 / 1.55 )
Lift Intake Exhaust
.200 126 108
.300 184 143
.400 224 163
.500 251 176
.600 257 183
LS6 2.5 Texas Speed CNC ( 2.02 / 1.575 )
Lift Intake Exhaust
.200 147 114
.300 209 152
.400 258 191
.500 294 207
.600 316 226
Lift Intake Exhaust
.200 126 108
.300 184 143
.400 224 163
.500 251 176
.600 257 183
Lift Intake Exhaust
.200 147 114
.300 209 152
.400 258 191
.500 294 207
.600 316 226
chevy02
09-07-2016 11:08 PM
