Please help me trying to swap a 2014 engine on my 2007 nnbs
Just spit balling some parts here but I'm pretty sure you are going to need the motor/transmission, wire harness, computer, upgrade your fuel system for enough fuel flow for the DI motor, motor mounts.
Custom tuning and figure out a way to make the gauges work. The ECO Tech 3 Controllers never had a 4L60e transmission so that's why I said transmission as well.
Avery@texas-speed.com
I believe the gen 5 has electric power steering. Might want to look into that!
You may be able to get a computer from the following places: GM, Speartech, or PSI. Speartech may be your best option at this moment, I would recommend calling them and seeing if they have any info regarding the harness and computer.
