PCV help
PCV help
I just did a nnbs intake swap on my 04 tahoe. I used the PCV line to the back of the drivers side valve cover. It has a PCV valve. Where should I hook the line off the front of the passenger side cover? I think it was to the intake before but there is no port for it on the nnvs intake. I've seen it run to the intake tube, but there's no vacuum there, right? What's the best way?
Avery@texas-speed.com
We have a breather on mine and well it runs fine. We use the PCV on the driver side and hooked that up, However I am about to add a catch can so I will change that up soon. If you want to check it out let me know. When we installed my TBSS intake it was really late and I was getting tired of messing with it, so we tossed a breather on it and its been fine. If there was an issue with the way it was set up you would have figured that out pretty quick and I would have had to change it before the tune.
-Avery
Ricky told me you had done that. If I'm understanding it correctly, the fresh air that comes in ends up going into the intake on the PCV side and it's not getting measured by the MAF so it's like a vacuum leak. However, if we tuned it while it was like that, it might throw it off a little if you were to hook it up to the intake now so it should be fine. I tuned mine recently without the fresh air return. I'll hook it up to the intake and retune the maf and see what the difference is. I expect it to be minor.
I remember now that these guys reminded me. I sued a step bit to drill a hole so that a hose nipple would screw into my intake tube on my last tahoe and just connected a hose from the passenger side valve cover to the nipple in the intake tube. I'll take a picture when I do it.
