Oil Pressure Question
I've noticed an issue with my oil pressure and wanted to see if it is normal or something I need to dig into.
When cold, 50 psi at idle, 60 at part throttle, and 70 plus over 3500-400 rpm.
When hot, about 30-35 at idle, 40-50 at part throttle, and tick under 60 at WOT.
Running 5w/30 Mobil One, and just changed oil.
I think the inability to go over 60 psi when hot regardless of RPM is an issue.
I don't think it is sending unit since it registers the higher pressure when cold.
Any ideas?
Any ideas?
Baltimore Whore
**** my 06 only shows 30 on the gauge at idle, and when it gets warm about 15-20 at idle, maybe 35-40 when driving. Only way to check is to put a mech gauge on it.. Seems low by the dash gauge but is still not low enough to be out of spech
Just a little worried since it reads so much closer to stock when cold (50 at idle, 60 at part throttle, and 80 at WOT).
I was going to install the new fuel pump and get it on the dyno and get some baseline numbers, just didn't want to blow up the motor because of an o-ring or bad oil pump.
superchomper2003
08-26-2015 09:39 AM
05GMC4.8
08-07-2015 09:55 PM
Ferocity02
07-17-2015 07:05 PM
