Oil cooler in my 5.3?
Hey guys! So I was doing a tranny flush on my truck since I got the temp up to 210 during a little cruise to Scottsdale(30 mile trip mostly highway,was 107 out) and was doing some pretty awesome pulls, friend of mine said he was doing about 110 in his 240sx and I was still pulling in him, so was doing some awesome runs.
Anyways! So I was thinking that since I did my e fan swap with the bigger radiator (05 Silverado) and it has the ports for an oil cooler. I service a bunch of 99-2014 Silverado for a company and see that they all have factory oil cooler lines, they are all 2500 6.0s but I was wondering if I order those factory lines from above my oil filter housing on my oil pan, to those coolers in the radiator, would I see a difference or would it kinda be a waste? I don't have much room up front since I have a tru cool 40 and a ps cooler on it already with my condensor and radiator, is this a good idea? Can get the lines for about 80 bucks. Cheap piece of mind or kind of a dumb waste?
Donyou have an aftermarket ps cooler or the factory one? Oil coolers are actually more of an oil warmer, the oil temp will basically be same temp as your coolant temps.. Unless youre running a separate cooler i wouldnt waste the time on it, much less the aggravation of them leaking... Oe or aftermarket they temd to leak....
Custm2500's Rude Friend
I see less oil degradation with an Oil cooler on my 6.0 truck. I assumed it was due to the oil cooler. I don't have an oil temp gauge though.
Ya know i never have, never even really thought about it, but its same principle as a trans cooler, running the trans fluid through the radiator will actually warm it up more that running straight through an afternarket/aux cooler, may only be a few degrees but wouldnt same principles apply, as far as oil degradation, couldnt tell you on that, better oil difference intervals, different driving tendencies between it and what ever else you have??? My biggest issue with the oil cooler lines is the leaking issue.... Very few and far between you see a set that dont leak....
When I say cooler I mean the color that's built into the 34 inch radiator from factory with the 2 lines.
Yes my truck has a factory ps cooler and not a factory oil cooler which I found odd..
Is there a factory oil cooler that goes in front of your radiator or you guys talking about the one into your radiator?
Well I'm wondering if I should just get those hard lines since they are only 110 bucks from my dealer or should I just run a external cooler from the same spot...?
Would I see a difference of is there any difference in doing this?
Run the factory cooler, my oil temps dropped considerably on my Express with the 350. Oil pressure stays much more consistent and the oil stays cleaner longer. In cooler weather it helps heat the oil up more quickly to boil out the contaminating moisture.
