Official NBS V6 to GENIII V8 swap Guide
Old 11-09-2006, 04:16 PM
FormerVendor
Derek @ EDO's Avatar
The power steering pump will will swap over as well as the alternator.The other accessories will not
RT's WT (04-18-2023)
Old 12-02-2006, 05:22 AM
LS1Tech Whore
Dirty 30's Avatar
Is the rearend from a V6 the same as a rearend from a V8???
Old 12-02-2006, 07:50 AM
FormerVendor
the rearend is the same,
but it could be a G-80 or Open diff.
I would recomend replacing the differential with a stronger aftermarket one such as an Eaton LSD or a Detorit True Trac.
The following 2 users liked this post by Derek @ EDO:
mikesanto70 (09-29-2022), RT's WT (04-18-2023)
Old 12-02-2006, 08:03 AM
formerly 1BADC10 (12/14/2011)
95ImpSS's Avatar
Nice writeup! Should change the "complete" word to "turn-key". <-- easiest
Old 12-02-2006, 08:20 AM
FormerVendor
Will do Ron. lol
Old 12-02-2006, 10:39 AM
Red00's Avatar
It did a search, but didn't come up with much about using the stock manual 5-speed when swapping to a v8. I assume it will bolt up fine, but what flywheel and clutch would you use? Where the only v8's with manual trannies 4.8's? Would a 4.8 flywheel and clutch work?
Old 12-02-2006, 10:56 AM
FormerVendor
The only concern would be the HP rating in which the 5 speed can handle, i believe you would also need the 4.8 flywheel and a heavy duty clutch.
You could always do a t-56 swap with a larger clutch, I just dont think that a stock 5-speed can take the abuse the larger V8 will give it.
What engine are you wanting to swap in?
Old 12-02-2006, 11:24 AM
Red00's Avatar
I'm not really trying to race it, just something a little better than this gutless v6. I just want to use the stock 5-speed tranny for awhile. Probably a 5.3 for now since they seem much cheaper than a 6.0. Later on might do a 6.0 and T56. All of the complete 5.3 I have seen have been auto's. If I got a 5.3 with a harness and computer for a auto, could I modify the harness for manual and have the computer reprogrammed?
Old 12-02-2006, 11:41 AM
FormerVendor
yes, you can do that. you should be fine if your not gunna race it.
get with Vince from FLT and ask him how much HP a tock 5-speed can handle, im sure he can give a good estimate
Old 12-23-2006, 02:48 PM
LS1Tech Whore
Dirty 30's Avatar
What about the Fuel Pump? are they the same?
Quick Reply: Official NBS V6 to GENIII V8 swap Guide
