Official NBS V6 to GENIII V8 swap Guide
Old 09-16-2015, 10:01 PM
  #141
Custm2500's Rude Friend
1FastBrick's Avatar
Originally Posted by Jose El Rojo Aguilera
I use the Pcm that came with the 6.0
That's your problem.
It will not work with the 03 up system for the cluster and everything else.
You will have to change the red connector to a green connector from your old harness and re use the original PCM. It will then need to be re flashed for a V8.
Or Re-pin the V6 harness by adding the injector circuits and reflash the computer for a V8
Old 09-17-2015, 11:14 AM
  #142
Registered User
Jose El Rojo Aguilera's Avatar
Ohh that makes sense what would you think it's the best thing to do and takes less time
Old 09-17-2015, 09:32 PM
  #143
1FastBrick's Avatar
Remove the red covers from the PCM connector and install the green one's would be the fastest/easiest. I would have to look at the Pin outs though to see whats different or changed between 01 and 03.
Then you just need an operating system that uses a mechanical throttle body. There were some that retained the mechanical TB and I know for sure a Van would have that.
Old 01-23-2016, 11:01 AM
  #144
Registered User
shawn9526's Avatar
Can someone help??? I have an 2007 classic and having issue mounting up motor mount to frame. one side mounts perfect and other side is off by maybe 1".
Old 01-25-2016, 01:02 AM
  #145
1FastBrick's Avatar
You have the wrong frame mounts.
Coil Spring Frames and Torsion Bar frames are different and have different frame mounts for the engine mounts to bolt to.
Old 02-16-2016, 12:32 PM
  #146
hondarider552's Avatar
OK so what exact engine mounts and frame mounts do I need? Original post is vague and my dealer is retarded and I'm close to that haha.
This is a 4.3 to 6.0 LY6...
Any help would be appreciated. Tried searching but can't find part numbers...
Truck is a 2003 2wd and engine is a 2008.
Old 02-16-2016, 03:44 PM
  #147
Are these the 2 brackets I need?
GM 15113848 and 15113847???
edit; Ordered those above part numbers from the dealer with my discount.
Old 02-17-2016, 12:17 AM
  #148
1FastBrick's Avatar
You did not state if you are coil spring or torsion bar front suspension.
Old 02-17-2016, 12:31 AM
  #149
1FastBrick's Avatar
15113847 RH appears to fit both
15113848 LH appears to fit Coil spring frame
15113849 LH appears to fit Torsion bar frame
Someone please correct me if you find out other wise.
Old 02-18-2016, 10:20 AM
  #150
Sorry, I have coils up front.
Quick Reply: Official NBS V6 to GENIII V8 swap Guide
