Nnbs factory head question
Got a 08 silverado yesterday day and noticed one head has 853 in it and the other I haven't been able to see yet. It's a 5.3 and I thought they came with 799/243 heads in the nnbs ?
Any one know if some come with 853 heads or did some one change it out along the way?
Thanks guy.
Thanks guy.
Avery@texas-speed.com
853 is a LS1 head. If you decide to keep the heads I would mill them 30 thou. The 853 came in 2 flavors. 1 casting has a notch on the exhaust side which was used to prying the head off the block, while some 853 castings did not have that notch.
If you have the notch you MUST run graphite gaskets ( 12498543 )! If the heads do not have a notch then you can run the LS1 MLS gaskets ( 12498544 ).
Good Luck!
Good Luck!
That is a good idea! You really never know what you are getting into when you buy a used GEN III / GEN IV vehicle. I have a buddy that bought a NBS escalade which we though was really slow and sluggish, and it turned out that someone had pulled the LQ9 and replaced it with a LR4.
8 Second Truck Club
Good Luck!
Good Luck!
