need help with procharger
Old 10-30-2015, 02:56 PM
lsx_production's Avatar
Default need help with procharger
i have a 02 silverado motor that i grabbed from the yard. still using stock water pump and i mounted the alternator on the lower right of the motor when looking at it from the front in preparation of running a procharger and not receiving these accessories from the yard. I have decided to piece together a kit and am trying to search for parts that i am having trouble finding. the first of which is a bracket that will fit my app. I want to run the SC at max and preferably use a six rib belt. If anyone has any idea where i can source this stuff please let me know. it would be very helpful. thank you
Old 11-01-2015, 05:43 PM
bump?
Old 11-03-2015, 01:11 AM
8 Second Truck Club
Blown06's Avatar
So many issues. Hard to answer.
Old 11-03-2015, 07:51 AM
Issues!?!?! I'm just looking for the right procharger bracket with tensioner and related parts...
Old 11-03-2015, 08:06 AM
Formerly ScreamingL
George C....'s Avatar
Whatever accessory drive you are using, you need to use correct bracket
Old 11-03-2015, 06:02 PM
agreed. where can i buy brackets w/ tensioner and the right underdrive procharger pulley? it seems as though i can source everything else without a problem. it needs to be a standalone bracket that runs a belt just for the procharger.
Old 11-03-2015, 07:06 PM
Formerly ScreamingL
Good luck with that one...most production use the serp belt
There is a HOB bracket i thino does what youre talking about
Old 11-04-2015, 12:03 AM
8 Second Truck Club
Blown06's Avatar
An underdrive crank pulley is a bad idea
Old 11-04-2015, 08:58 AM
My mistake. I mean crank pulley.
Old 11-04-2015, 09:02 AM
Right. That's what I noticed and i don't think it will work since I plan to run a d1sc at max and don't think I will be able to with a six rib and factory crank pulley size in combo with the smallest 6 rib pulley.
Quick Reply: need help with procharger
