Need help with my 5.3 to lq9 swap
#31
Tell them you need the complete head lamp harness it warped in the same loom. You don't need the main fuse box and it wont work in your truck. You also need the plug that ties into the PCM on the main engine harness.
There is pictures here and it tells you how to do the swap. 06 chevy e-fans 01 chevy
#34
Good morning everyone, so last night I was looking at the DBC throttle body and tried putting it on and noticed it won't fit because of the fitting that comes off of the 06 intake, it has the same fitting coming off the 2000 throttle body is it as simple as canceling one of them or is there more to it? Oo and one other thing how big of an engine hoist do it need?
#35
So long as you get your dirty air you should be fine, id pull the elbow out of the throttle body and tap it and put a pipe plug in... As far as engine hoist goes, as long as its tall enouh to get the engine over the core support youre fine... Engines are fairly lightweight comparatively...
#36
#40
Had a quick question what is that flexible hose that goes from the manifolds to the intake ? The new engine does not have it, I wouldn't need it right? Here is a picture .
