NBS Truck with NNBS intake. Which intake tube fits w/stock fan?
I have a 2003 rcsb with the stock, non electric fan and huge shroud. I just installed the NNBS intake/tb. The design of this intake angles the throttle body upward, which changes the angle of the intake tubing. Since I still run the stock tubing, it has the large sound baffling attached to it, and the new angle is forcing it into the fan shroud. It also makes the intake tube sit higher, almost hitting the hood when it closes.
I'm guessing just about any aftermarket air intake will come with silicon couplers and two hose clamps to attach to the throttle body, which will give me enough wiggle room to offset the angle. I was planning on getting some type of aftermarket air intake tube/filter anyway, but will any aftermarket intake fit this NNBS intake and also clear the upper fan shroud?
If you have an NBS truck, stock fan, and NNBS intake, which tubing do you run?
I'd swap in electric fans if I were you, but Airraid MIT tube 200-912 should work for your application. The fan shroud doesn't give it a lot of clearance so part of the tube bottenecks down to 2" or so.
Thanks
