milling heads
Old 03-07-2017, 06:12 PM
Registered User
Jon91's Avatar
Default milling heads
How much power will i get if i take my 5.3 heads off and get them rebuilt and milled .030? I dont really want to remove the heads but who knows.
I currently have these parts:
pac1218 spring
7.4" chromoly pushrods
yank 3200 stall
4.10s
I want to get the 228R .600/.600 112lsa cam.
How much will i gain by having the 706 heads worked on?
edit. i was actually going for the 224r cams but i got the stall and decided to go a little bigger.
Old 03-08-2017, 07:38 AM
Drspencer's Avatar
If you're going through the trouble of rebuilding them, may as well stick a 2.00" valve in there....or grab a set of 243/799 heads... There's a couple sets on eBay from some machine shop in Texas that are less than $300 shipped. Granted they need machining...but just a thought.
Old 03-08-2017, 05:07 PM
Avery@texas-speed.com
Slow05CC's Avatar
Taking the heads to 58cc will get you around 10.0:1 compression. That would be worth a little bit of power, but not enough to pull them off, pay for the work, then buy all the parts to put them back on.
If you wanted to do something worth the hassle of pulling them off, have them CNC ported with larger 2.02 intake and 1.575 exhaust valves. Then mill them to around 58cc! The head work combined with the 224r ( 224/224 600/600 112+2 ) would make a nice jump in power. The 224r and a 3200 should work pretty well together, if you feel like it is sluggish down low install some 410 gears.
If you have any questions or want more information on clearance, specs, ect send me a PM
-Avery
Old 03-08-2017, 08:36 PM
03sierraslt's Avatar
Not sure what your truck configuration is but on a 5.3 I would keep it 224 and lower. The later you make your intake valve close the more dynamic compression you'll loose and on a smaller motor in a heavy truck that's gonna hurt lowend.
Pull a couple degrees intake duration and run little exhaust bias. Not sure your intake and exhaust configuration but on a 5.3 even a 220/224 112+3 would be strong. That has a 3 degree earlier IVC then the above mentioned.
Now if this is a stripped down standard can 2wd then have at it. Just my .02
Old 03-09-2017, 09:21 AM
Slow05CC's Avatar
True Story! Some people just dont understand this concept. They just get carried away with "choppy idle" because X buddy runs X cam and it has a super rough idle, or they hear these videos all over the interwebs of guys running big 22x, low 23x cams in these small mill motors, but what they dont understand is how poorly the truck runs, or complain that all their bottom end is gone. The 224r is about the most intake I would recommend on a 5.3 truck, and maybe a tad wider if the 5.3 is in a light weight clutch car. I can say that out of all the cams/combinations I have ran in my pile, the 220r ( 220/220 600/600 112+2 ) combined with a 3200 stall and 4.10 gears was by far the most fun set up. Power all over the board, nice low and mid range, nice clean ( not choppy ) sounding idle, and didnt eat up tons of gas.
BV85 (03-21-2017)
