Maf
Size wise yeah it matters but you could have it right after the filter like stock or you could have it further up the intake tubing if you wanted to too.
Just make sure it's not at any bend and has a straight flow of air/tubing before the MAF to get proper readings.
Maf
yes, you will need to tell the PCM, anytime you
change the size of the air tube, MAF or T/B you need
to change the size in your tune for the right A/F
ratio.HPT has a section to do that.
