Mad 2 step launch.
You can use either the Blue wire switched to Ground OR
the Blue/White wire switched to +12V. You only need to use one of these. This just turns on the unit.
Instructions
Instructions
also pin to set rpm what number on back of box should I set?
11 Second Club
Also you can check the 2 step for proper function by looking for the red led on the side of the box where the RPM dials are. The LED only illuminates when armed
