TB bypass, now blowing white smoke
Old 12-29-2004, 09:25 PM
Default TB bypass, now blowing white smoke
i just did the tb bypass mod. I leaked some coolant during the process, now i'm blowing white smoke out of the exhaust. will this go away? why is it doing that?
Old 12-29-2004, 09:33 PM
quicksilverado's Avatar
White smoke is water in the exhaust. AKA steam. If you did the bypass correctly it should go away.
Old 12-29-2004, 09:56 PM
Deckhand's Avatar
I remember some guy a while back did this mod incorrectly and and his oil was all watery because he connected the wrong lines together.. i forgot though.. it was a couple years back.
I think he connected the coolant line to some line going into the head.. not sure though.
Old 12-29-2004, 10:11 PM
it seems to be going away. I drove it a few miles and it is getting less and less. I don't understand though how i could have gotten moisture into the exhaust.
Old 12-29-2004, 11:12 PM
14 Second Truck Club
Whistlin00's Avatar
Dont you think your tb may freeze since you live in a cold climate.
Old 12-30-2004, 05:12 AM
Faze2183's Avatar
which line do you by pass??? and what all do you need???
Old 12-30-2004, 05:43 AM
I hope it doesn't freeze. That would really suck. I've read on here from members who live in even colder climates that it shouldn't be an issue and hasn't been for them. The reason I did this mod is because my throttle was rubbing up against one of the lines going into the TB because the TB is over there now because of the whipple. This way, i won't spring a leak again.
turbo6c3
10-05-2015 06:11 PM
carid
10-01-2015 09:22 AM
TrickTurbo
09-23-2015 08:41 PM
Go5.3tt06
09-14-2015 02:11 PM
Quick Reply: TB bypass, now blowing white smoke
