LQ9 with nv3500 flywheel problem! Help!
Old Mar 5, 2011 | 02:15 PM
5spdsilvy's Avatar
Default LQ9 with nv3500 flywheel problem! Help!
I have a 06 lq9 and im gonna run my nv3500 for the time being. im in the process of putting the motor in and now i need to fix this before i go any further. My question is my flywheel im using from my 4.8 is touching the oil pan on the lq9. Do they make some kindof spacer or something to fix this? The crank on the 4.8 has a longer snout than my lq9. Any help is greatly appreciated!
Old Mar 6, 2011 | 11:05 AM
budhayes3's Avatar
PT's Slowest Truck
I believe that the 99-00 4.8's had a longer crank like the 6.0's did (at least the ones with manual transmissions did), so yes, you will need a crank spacer. I don't have the part number, but I do know that there is a crank spacer available from GM
Old Mar 6, 2011 | 01:34 PM
5spdsilvy's Avatar
I figured it was either a spacer or get a newer model flywheel.
Old Mar 6, 2011 | 09:38 PM
budhayes3's Avatar
PT's Slowest Truck
I guess that either would work...honestly, I'm not familiar of anyone running a spacer with a flywheel now that I think about it a little more, only with a flexplate and auto, not saying that it doesn't work or hasn't been done...
Old Mar 7, 2011 | 02:21 PM
Bumpers's Avatar
i think the flywheel outa a 02- 5spd truck is what hes needing
Pimpinpete
43
Dec 22, 2017 08:13 AM
drummer0415
11
Oct 24, 2015 08:16 PM
lxcoupe
Sep 29, 2015 09:20 PM
sTNT971
Sep 26, 2015 06:27 AM
97_ek
Sep 23, 2015 09:16 PM
