Lq4 going into lifted half ton. HELP PLEASE!!
Old 09-30-2016, 10:06 PM
willhorne22's Avatar
OK sounds good, I'll do a cam. Can yall verify those pistons and rods will work with my 01 lq4 crank. I dont know if I can pick the proper cam before doing the 4l80e swap, and I won't be doing that swap for a while. If i ruin the 4l60e sooo be it. Maybe I just cam it when the new tranny is going in?
Old 09-30-2016, 10:58 PM
slvrram's Avatar
It's significantly easier to do the cam with the motor out obviously, so if you're going to do it, do it now. Spec it for the whole setup ie: 80e/higher compression 6.0. With that in mind though, you have to draw a line in the sand somewhere. Builds easily turn from simple motor swap to $20k build. Set your sights on a goal and remember that these guys are not spending their money, they're spending yours. Keep it realistic and it'll get done.
Old 10-01-2016, 08:07 AM
Ok, I was worried it would drive like a dog or something with a cam spec for a different tranny and stall, but hell realistically I need to get my 4l60e out of it as soon as I can. That way its still worth money when it comes out lol. Yah I won't be spending that much. Its a full rebuild but I'm keeping factory crank and just got those LS2 pistons and rods for $268. I was worried I was going to spend a lot more in the bottom end, so I feel good about that.
Old 10-01-2016, 08:48 AM
Reading through the forums, I am seeing the Cam suggested quite a bit. BTR TRUCK STAGE II CAM Specs are 212/218 .553/.553 113+2.
Who all thinks this would be a good upgrade?
Old 10-01-2016, 10:35 AM
Wolftrk99's Avatar
Ive already spent mine.... Hence the reason i am saying go ahead and do it once and be done with it!!! But make sure you get the cam you want/need the first time around and Not have to go back in and spend money on another cam down the road....
I would think in a 6.0 the stage 3 or 4 would be a better choice in a truck with your specs, unless you decide to go with the l92 heads.... Then you need to look into the ls3 style cams.
The rods/pistons should be a direct bolt in, the cranks if memory serves have the same casting number just different reluctors
Old 10-01-2016, 10:57 AM
I have a gauge for that
Atomic's Avatar
I thought your name looked familiar, glad you like the coilover swap!
I second going ahead and doing a cam while the motor is out. Its a whole lot easier that way. That BTR cam would be a good place to start and should be ok with the factory converter, but if you use a low stall aftermarket one (in the 2400-2600) range it will help 60ft tremendously.
Old 10-01-2016, 11:31 AM
Wolftrk99's Avatar
Just got an email from BTR about a cam install special they are running at the moment....
Old 10-01-2016, 11:38 AM
Wolftrk99's Avatar
If you are dead set on keeping the 4l60 in there temporarily a 4.2 trailblazer converter will get you a decently higher stall and not be a $4-500 tempirary fix.... I paid $118 for the dacco converter i had in my truck before i built the new trans, and had found another for $98.. It stalled somewhere around 25-2600 in my truck
Old 10-02-2016, 08:37 AM
I'm not dead set on keeping in there. I just know I will have the motor done and will really want to test it out. So I can slap a trail blazer stall in there and that will be better?
With the pistons I bought is my compression 9-6-1. How do you figure out how much you want to shave off the heads?
Old 10-02-2016, 08:52 AM
Wolftrk99's Avatar
My understanding is with the flat tops you shoukd be closer to 10/10.5:1... Tb converter isnt the be all end all, but it is an upgrade over stock.... Just make sure you get a decent converter and install it properly they had an issue with hub height on them getting screwed up in the reman process... Had a build i did as a sidejob, they put the converter in and ate the pump... Turned out the hub wasnt tall enough!!! Dacco is usually pretty good though!!
jik294
10-21-2016 12:44 PM
mike187
07-26-2016 10:17 PM
Jsleeman
07-17-2016 12:16 PM
tlindo
07-14-2016 12:14 AM
Quick Reply: Lq4 going into lifted half ton. HELP PLEASE!!
