LQ4 crank bolt missing
Old 02-04-2015, 11:40 AM
  #21
dirt track racer 81's Avatar
Originally Posted by GMCtrk
That's a cool trick - never heard of that one. How much does the bolt cost?
Never use any bolt to pull the pulley on with, stock length or longer. Before I started building my tool I used the "longer grade 8 bolt" method and fucked up a crankshaft on a guys truck.. That was when I started building my tool.
Old 02-04-2015, 02:35 PM
  #22
Formerly ScreamingL
George C....'s Avatar
We all know you've built your tool way before time
Old 02-04-2015, 03:40 PM
  #23
Is that an old joke?
Old 02-12-2015, 10:46 AM
  #24
DAH32's Avatar
Even with a light or long pick or screwdriver, there appear to be no threads.
Hmmm. Not to sure about this.
Old 02-12-2015, 10:53 AM
  #25
TXsilverado's Avatar
get a crank bolt and see if it will thread. it's pretty deep in there.
Old 02-12-2015, 11:25 AM
  #26
DAH32's Avatar
The key weight on the crank sits a pretty good way back. The balancer does not go over the key weight. It seems to butt up to that.
Is this balancer a press fit?
Old 02-12-2015, 11:42 AM
  #27
11 Second Hall Moniter
AKlowriderZ71's Avatar
Yes it is. The keyway is for the timing gear, not the front pulley.
Because the engine is internally balanced, the lower pulley can go on in any position. Unless the threads have been stripped out of the crank snout. Pretty much junk at that point...
Old 02-12-2015, 11:45 AM
  #28
DAH32's Avatar
True.
As I already said. There appear to be no threads. The hole is only about 2 1/4" back. Machine shop can fix that or extract the bolt.
My question was is the balancer pressed on vs being a tradational threaded style.
Old 02-12-2015, 12:33 PM
  #29
DAH32's Avatar
Upon looking at doing some more observation. It looks like the orginal balancer bolt has broken off right at where the threads start.
Old 02-12-2015, 12:55 PM
  #30
remove the crank pulley, and see if there is enough meat in there to get a grip on the bolt to extract it. penetrating oil and heat helps. ez out it from there if you cant get a vice grip on it.
Quick Reply: LQ4 crank bolt missing
