A little imput
A little imput on 99 6.0 swap
Ok so im doing a 99 6.0 swap in my 2000 4.3 silverado. Ive got everything (ecu, mounts, pretty much every ecc. on the motor) but cam and convertor .. I was planning on running my 4L60 but i heard that the crank is longer on the 6.0 so it wont work with my trans .. any truth to that??
I know im supposed to take off the 6.0 flexplate and use my flexplate from my 4l60 ..From what i understand, from all my reading since im useing a 2000 and up 4l60 theres no issue..
the heads are 873 (iron heads) .. I was planning on boosting the truck and leaving the heads on it but this 4.3 to 6.0 project is alittle more money than i thought.. lol
Custm2500's Rude Friend
The crank is too long on 99-00 6.0L to use with a 4L60E transmission behind it. It will only fit with a Hybrid Converter. $$$
In 01 they went to a removable spacer and used basically the same crank as the 5.3L
01- up LQ4 6.0L you remove the spacer, flywheel, and bolts and use a flywheel and bolts from a 6.0L, 5.7L, 5.3L, or 4.8L that was bolted to a 4L60E.
yea im trying to find a set of heads now.. and sad to say i already bought the motor for $1100 with 100k .. I was looking into going with a magic stick cam so i figured a spendy stall (3500) was in my future ...
https://ls1tech.com/forums/conversio...ent-4l60e.html
After reading that Ill just go with a art carr stall and try to find a cam that will work better with a 2500 -2800 stall... Anybody have any suggestions ? I just want a 400-450hp to the wheels toy.. I might hit the drag strip once of twice but thats it..
