Lifter tick cheap fix
so my tahoe got the dreaded lifter tick at 150k miles. started planning on doing the DOD delete and CAM/lifters. Saw some youtube videos where people were cleaning the lifter with some B12 carb cleaner and the noise went away. Thought I would try it and it is super quiet now! Seems to idle better too. I really dont know how long this will last before it goes bad again but at least I have more time to save up money. Just a note that it seemed like my pushrods had blockages in them, spraying the carb cleaner in the pushrod seemed to clear it out and allow the oil to get to the lifter easier. thought i would post my experience for others that might have the same issue.
still going strong. just did another oil change with some full synth high mileage, still quiet and idles smooth. havent really checked the burning oil level but i pulled out 5+liters out for the oil change so it may be better but i dont know how much oil was put in last change. this time i did the oil change myself to be sure.
so yeah, no reason to rip out your lifters right away, this worked well for me. didnt even do the motor flush.
Video is painful to watch, dude is super annoying.
Cliff notes: very obvious lifter tick; he pulls valve covers, rockers, pushrods. Squirts lots of B12 carb cleaner down pushrod guide hole into tops of lifters. Replaces pushrods and again squirts B12 down them. Then adds Gunk motor flush to existing oil, runs it, then changes oil. (well we assume he does! not actually included in video. But the engine is running without the tick.)
The B12 seems like a reasonable approach before tearing into it to replace lifters. Like Jeff, I don't know if I would be so quick to do the motor flush product as I'm not a big believer in them, but again if it was a last ditch effort, why not. Just be sure to change the oil immediately afterwards and I would personally be on an aggressive oil change schedule for the next couple of times to be sure I had all that crap out of the system.
Dunno if it would have helped my old work truck 2009 3500HD with the 6.0; it went from bad to really bad in a hurry. We did pretty regular oil changes on it but in retrospect I wonder if our shop was even using the correct grade of oil since they bought in bulk (HUGE tanks.) I would bet they just used what they had and it may not have been correct.
Bad
Worse
Richard
Bad
Worse
Richard
yayo3p
10-20-2016 12:04 PM
slvrram
10-12-2016 03:39 PM
TombstoneAK
10-04-2016 12:13 PM
