Let's talk intake manifolds
Old 01-23-2014, 06:13 PM
454navyss's Avatar
Default Let's talk intake manifolds
Has anyone compared a factory to a Holley Hi-Ram, Edelbrock Pro-Flo XT, and FAST LSXRT 102? I have found individual results but none with a similar test foundation with only intakes being changed.
My truck has the factory 78mm truck intake and I'm thinking about switching to an aftermarket manifold, I don't want to lose much if any low end torque but definitely want top end horsepower gains. I know with any of the three aftermarket intakes I will also have to buy a matching throttle body, and I'm assuming fuel rails and injectors as well, can anyone confirm this?
Old 01-23-2014, 06:18 PM
Byrdman11's Avatar
The fast intake is the only one that wouldn't kill the low end torq. The nnbs intake with the 87m tb would be nice too.
Old 01-23-2014, 09:35 PM
454navyss's Avatar
If I keep my current 3800 stall and use nitrous off the line like I intend to, maybe the loss of low RPM torque won't affect me much.
I can't find flow numbers on any of these intakes, all I see is "25hp gain", etc. someone has had to have tested the flow on these manifolds.
Old 01-23-2014, 09:52 PM
I have a gauge for that
Atomic's Avatar
Most guys dont spend $2000 on intakes just to test for a 5hp difference....you will be fine with any of them, they are all good. Take your pick of the one you think looks the best.
Old 01-24-2014, 07:22 PM
RezinTexas's Avatar
I'm really impressed with the ported LSXRT. It made a massive difference vs the Gen 3 intake/TB. Its a completely different motor above 4k, and it didn't loose anything down low.
With the Patrick G tune, it didn't lose any driveability either. Its no different than the 78mm OEM unit in that respect.
I have no experience with the other intakes you listed, so I can't offer a comparison.
Old 01-24-2014, 08:10 PM
454navyss's Avatar
I'm leaning towards the LSXRT, as of right now. I'll need a throttle body, fuel rails and some hardware but maintain my fuel injectors that I'm currently running, correct?
Old 01-25-2014, 06:22 AM
RezinTexas's Avatar
See post 14. I was able to use the stock fuel rail, however it was a PITA, and its an eyesore.
https://www.performancetrucks.net/fo...2500-a-520418/
I'm running 36lb FAST injectors, however that depends on the rest of your setup.
To get the best results with the LSXRT, I recommend the ported Tony Mamo version, and tuning by Patrick Guerra.
Old 06-19-2014, 01:34 PM
gnd111's Avatar
My Fast LSXrt killed low end but made 40more RWHP than my stock intake at 6400rpm.
Old 06-21-2014, 08:45 AM
Blackpanther99's Avatar
Best bet is LSXRT
Old 06-21-2014, 08:53 AM
TXsilverado's Avatar
Guess im the only one that isnt wild about the lsxrt. The quality isnt there for the money, and a lot of the time im reading about fitment or tuning issues. If you intend to run nitrous, the vic jr with a nice plate is hard to beat. The 4150 throttle body is a must and a single plane speced cam is a must.
Quick Reply: Let's talk intake manifolds
