knock sensor corrosion? - PerformanceTrucks.net Forums
Thread Tools Search this Thread
Old 09-19-2009, 05:40 PM   #1
GMCtrk's Avatar
Default knock sensor corrosion?
Put another manifold on today and it seems my hissing on the highway at load in 4th has gone away. So I assume I cured some sort of air leak. Anyways, at WOT I'm still getting the damn 8 degrees of KR. I'm fed up and about ready to find a new hobby. While I was there I did happen to peak at the front knock sensor and see it corroded and some on the wall too. I couldnt see the rear sensor. Can this cause knock like I'm getting? I dont hear a DAMN THING like knock at WOT. I apologize for the poor pictures (Iphone)
GMCtrk is offline   Reply With Quote
Old 09-19-2009, 07:59 PM   #2
replace them. yes they could be causing your problem. esp if your not hearing any knock.
Truckshop is offline   Reply With Quote
Old 09-19-2009, 08:56 PM   #3
I would replace them both. I just replaced both on my 01. my front looked fine my rear looked x50 worse than yours. I also had about 1/8" of water and rust sitting in the cavity of the rear. I sealed the top boot with high temp rtv. to keep the water from getting back in.
icetraxx01 is offline   Reply With Quote
Old 09-19-2009, 08:59 PM   #4
GMCtrk's Avatar
I did not visualize the rear sensor. From what I've read it's usually much worse than the front sensor so I expect mine to be the same. $90 for the sensors from SDPC
Old 09-19-2009, 09:03 PM   #5
PT's Slowest Truck
budhayes3's Avatar
Either way you're eventually going to have to replace them and build a dam with RTV (there's a TSB in reference to knock sensors corroding, check it out on your AllData). It makes sense that the knock sensors could be sending false signals considering how corroded they get. I *think* that there's a sub-harness to the sensors that you'll probably want to replace also.
budhayes3 is offline   Reply With Quote
Old 09-19-2009, 09:05 PM   #6
GMCtrk's Avatar
Why would I need to replace the harness?
Old 09-19-2009, 09:18 PM   #7
hirdlej's Avatar
Just do like me and disable the knock sensors. For every knock I have it pull zero degree of timing. If it's knocking you'll hear it. Who needs a PCM to tell you what to do?
hirdlej is offline   Reply With Quote
Old 09-19-2009, 09:20 PM   #8
GMCtrk's Avatar
Quote:
Hmm, I'd be a little weary of doing that just incase it is indeed knocking. You'd think that with 8 degrees of KR I'd hear something but I know there is knock that isn't audible sometimes.
Old 09-19-2009, 09:27 PM   #9
hirdlej's Avatar
People drove cars for years without knock sensors and they never blew up. I have a hard time letting the computer control certain things that I don't wish for it to control. Such as disabling the IAT spark tables and anything else spark related that's not coming directly from the spark table. If it's 150 degrees out or 150 below, I want to be in charge of the spark tables, not the PCM. I'm old school I guess......
Old 09-19-2009, 09:28 PM   #10
GMCtrk's Avatar
They also had much better gas then too.
I always run shell 93, but still I think it's questionable.
I'm debating running some race gas when my tank gets low and see if I still have the same KR. If so then we know what the problem is.
Thread Thread Starter Forum Replies Last Post
Please Help!!! Pimpinpete GM Engine & Exhaust Performance 39 03-08-2016 04:07 AM
issues after cam install bearden86 GM Engine & Exhaust Performance 26 11-15-2015 04:58 PM
IAT sensor placement JordanH FORCED INDUCTION 4 10-03-2015 04:59 PM
swapping alum block for iron trevorh1 INTERNAL ENGINE MODIFICATIONS 4 09-27-2015 09:47 PM
map censor question WICK3DxGATA FORCED INDUCTION 4 09-24-2015 07:56 PM
Tags
1500, 1999, corosion, corroded, corrosion, gmc, knock, location, lower, lq9, sdpc, sensor, sierra, silverado, voltage
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
