Knock activity possibly bad fuel?
#21
I just spent 10 min listening to the motor very carefully No abnormal noise at all no knock no ping nothing that I can hear. Thats all the time I had for diagnosing I am about to go drop it back off at the shop.
#23
Ok good thats what I wanted someone to tell me! There is alot of bad information out there about P0332 mostly on other forums.
Now I have read that it if the code stays on for an extended period of time it could put the truck into limp mode.
Also I forgot to mention that 3 weeks ago I rerouted and replaced my fuel evap canister because It was clogged with mud. I highly doubt they would be related in anyway but that was replaced recently.
#24
#26
Glad to know it won't put it into limp mode if the issues wasnt resolved.
The shop changed the sensor again for free and I have put aboout 20miles on it so far without the light coming on. If I make it to work and back tomorrow without the light coming on I guess it will have passed the test.
I Knew the evap system has nothing to do with it. Just seems like things like to go wrong one right after another.
#28
#29
I think you might be right that they torqued it improperly. I put 70 miles on it today and 10-15 ignition cycles with no check engine light so I believe the problem was cured! Yayy Thank you guys for the help last thing I wanted to do was have my motor blow up in the middle of South Dakota lol.
#30
Custm2500's Rude Friend
It won't blow up. It just pulls timing and the mpg goes down a little bit.
That's the thing with electronics. Sometimes there bad right out of the box, sometimes they last 5minutes, an hour, a day, a week, or even a month and then they crap out.
You never know untill you install it.
