InfernoHoe's Riddle... Please read & help if you can
Old 05-23-2015, 12:19 AM
Infernohoe's Avatar
Exclamation InfernoHoe's Riddle... Please read & help if you can
I thump very fast at 70 mph. I am only heard when driven next to a wall. When I speed up I thump faster, when I slow down I thump slower, but I am not related to engine speed only to ground speed. I am not coming from the tires and I don't think I'm coming from the engine. I set off knock sensors but I am not a knock.
What am I?
Hint I am NOT the busted and blown to bits sway bar end link that InfernoHoe Had to replace before right before work and "ruined" his favorite fishing shirt
Old 05-23-2015, 03:11 PM
Infernohoe's Avatar
Anyone out there? Am I truly alone here?
Old 05-23-2015, 05:55 PM
FFDP's Avatar
Does it change from 2wd to 4WD??
Can you lift the vehicle on 4 jack stands and run the truck and see what you can hear from under it??
Old 05-24-2015, 03:44 AM
Infernohoe's Avatar
Hey FFTP, Thanks for the reply. It is only 2 wheel drive. Also I have been underneath the truck while the motor was running and aside from a ticking kind of noise from the motor no tap, knock, thump, boink, boom, nothing. I don't have any jackstands to actually run it on. It is only when the vehicle is in motion though. Checked the easy things like tires and suspension to no avail. Ill see if I can fashion up some stands and check it tomorrow morning In gear.
Old 05-24-2015, 10:28 AM
Mark Johnson's Avatar
DS balance.................
Old 05-24-2015, 10:40 AM
Infernohoe's Avatar
DS balance? I dont understand what you mean. Are you talking about the tires?
Old 05-24-2015, 01:22 PM
JL Sargent's Avatar
Let somebody else drive it while you ride in the back with the windows down and hunt for the root cause of the noise that way.
Old 05-24-2015, 02:04 PM
I have a gauge for that
Atomic's Avatar
Sure its not the road itself?
Old 05-24-2015, 03:26 PM
Infernohoe's Avatar
Tried and failed cant get close enough to even begin to figure out where aside from under the truck
Positive
Old 05-24-2015, 11:11 PM
Infernohoe's Avatar
Damn exhaust was too loud to find it today. I will try again tomorrow.
Quick Reply: InfernoHoe's Riddle... Please read & help if you can
