Pinched O-ring on oil pickup tube
Old 06-17-2019, 10:09 PM
hot66's Avatar
Default Pinched O-ring on oil pickup tube
Opened up my '08 L76 engine Saturday and found this pinched o-ring on the pickup tube. I was amazed to find this, because this engine had 228,380 miles on it when I pulled it out.
While it never had great oil pressure, it always had enough.
Since I had all of 16 the lifters dealer replaced at 99k under warranty, and I pulled it out at 228k due to a another failed AFM lifter that eventually ate the cam, I wonder if this was a contributing factor to the lifter failures.
I bought with the truck with 24k on it, so I don't believe the pan or timing cover had ever been off, the dealer only removed the heads to replace the lifters.
Even with all those miles, the cylinders still look much better and the piston skirts show far less wear than the iron block LY6 I replaced it with, so I am going to rebuild the L76 and drop it back in its home.
Just going to mill the heads .020, add some low mileage flat tops and a summit level 1 truck cam, ws6 store ported oil pump, and comp's ls6 replacement beehive springs, along with all the bearings, rings, and gaskets, etc.
The LY6 ate a cam and lifter recently, at approx. 50k after the swap, and when I pulled it out to replace the cam, #4 cam bearing (next to the bad lifter and cam lobe) had spun.
It has an LS9 cam, but I believe now that the wrong springs were installed by the seller.
I know the iron LY6 block it can be fixed, so I won't scrap the it, I'll just save it for another project down the road.
You can be sure I'll triple check it, but do you have any suggestions on how to avoid pinching the new o-ring?
Thanks,
Jeff
Old 06-18-2019, 03:56 PM
madmann26's Avatar
Thanks,
Jeff
Plenty of lube.
Old 06-18-2019, 05:59 PM
RB04Av's Avatar
Plenty of lube.
White lithium grease or similar, liberally slathered on it.
The one in the photo looks like it just barely missed being fatal... doesn't look like it leaked too terribly bad. Sometimes ya just get lucky I guess.
marineusmc4
04-25-2019 11:40 AM
aldrichg9
18
06-16-2014 05:30 AM
kelsey_canard
01-17-2013 12:49 AM
thunder550
29
11-14-2006 11:51 PM
RoninsDenali
13
07-26-2006 08:54 PM
Quick Reply: Pinched O-ring on oil pickup tube
