IAT Sensor Relocate with Pics
#21
How do I change this text
I would be if you yield better (or worse) performance out of move your IAT around, your VE table is way out. Especially if the PCM is using complex cylinder charge logic....
#26
11 Second Truck Club
This is another good thread w/ links to three others on relocating the IAT sensor to the GM EGR block-off on the intake, just behind the TB.
https://www.performancetrucks.net/fo...at-mod-404701/
#27
Interesting.
On my 97, the stock IAT is divorced from the 75mm aluminum body MAF.
My Marine Intake uses a combined IAT/MAP sensor that sits in teh top of the upper plenum. The stock truck sensor is simply a MAP sensor, so I removed the marine IAT/MAP combo and am running the truck MAP.
I have a new 85mm plastic body truck/01+ Vette MAF with an integral MAF/IAT sensor.
I bought the MAF/IAT leads for an LS6 Vette and got 5 of those cool butt connectors with the integral sealant.
So I have 3 options for IAT
1)Integral MAF/IAT
2)Divorced IAT in air intake tube
3)IAT/MAP combo that senses actual air temp inside the plenum.
I wonder if there is really a difference beween the 3?
peace
Hog
1)Integral MAF/IAT
peace
Hog
#28
A lot of the difference is in the sensor itself, not necessarily its location. I would want to use either a IAT like the one in this thread possibly, or the old msd2320 piece which is discountinued but it appears is still available per google.
