What should I be shifting at?
Just curious on a few things with my tune i'm working with Justin on. What should I be shifting at? I seem to be shifting early (6100-6200) and it doesn't quite pull up top like I think it should. idk maybe im hoping for too much with it.
Set up-
1999 RCSB 4x4
6.0 LQ9
11:1 CR
233/239 .595/.603 112
243 heads milled slightly, dual .650 springs w/trunion upgrade 7.4" pushrods
TBSS intake with 92mm DBC 4" CAI
LT and ORY into 18" Magnaflow with full 3" pipe back to the bumper(could this be a restriction? Maybe I should cut it off before the axle?)
Stealth 340 pump
44 lb injectors
BB Autocal Tune 93
Efans
4l80e with shift kit
Circle D 3600 Billet Multi Disk
3.73 gears with 275/45/20 (28.5") on stock 20s
Tru Trac
Video- kind of sucks with it spinning and shifting to 2nd, but what do you think?
Set up-
1999 RCSB 4x4
6.0 LQ9
11:1 CR
Stealth 340 pump
44 lb injectors
BB Autocal Tune 93
Efans
Tru Trac
Baltimore Whore
I would be shifting a little later, around 65ish. Also when you do your runs leave the trans in 3rd so you don't get that down shift.. I honestly think that is to much cam for that heavy truck, the converter is just on the small side IMO..
Thats kind of what I was thinking, around 6500. I normally do have it in 3rd I must have not been paying attention.
I was afraid of that, I was trying to go as big as possible and still be able to daily it, hence the large end on the cam and small end on the converter.
Cammed4ever
09-30-2015 03:38 PM
