View Poll Results: 206/212 or 212/218 for daily driven cam
206/212
46.67%
212/218 low lift
53.33%
200/208
0%
Voters: 15. You may not vote on this poll
I want a "Low end torque cam" for my 04 4.8L
#32
Needs more displacement. 4.3 v-6 is .5 less thatn athe 4.8. The 4.8 is .5 less than the 5.3. Big difference. Even withe the two cylinders missing, tThe 4.8 is just too small
#35
Originally Posted by RSTSilverado
Would this cam be good for my 5.3L? Where can i get a cam motion cam? Also the alternative GM cam, would that be a good stealthy cam that will make decent power?
Originally Posted by Black Blown 02
Naked, do you have the dyno sheets?
Originally Posted by Suddog
Ok guys I went with Kim Allens' Cam Motion Camshaft. Now comes the hard part...putting it in. Anyone know of someone trying to get rid of a set of LS6 or 918 springs?
#37
I'd buy them new (GM P/N 12565117), you can get them for ~$5.50 each, or $88 for all 16 of them. Springs are too important to be messing with used or unknown.
Alternatively, I ran across this part (GM P/N 12499224) that might actually be a kit containing all 16 LS6 springs. If someone can verify the part number....it's only $44.80.
#38
Naked AV,
Tell me all about your cam. Where is the true power at (rpm)?
I have 3.73 gears in the back. Are you still in CA? If so does your truck pass smog with the new cam?
#39
Naked AV,
Seriously, the power is all over. And yes, I'm in CA, but there will be no problem passing smog, though I don't have to do it until 2008.
