Cam questions
Cam questions
GOing to put a cam into my A4 2500 with a 6.0. What cam should i go with. And what else do i need to make it run right. any imput would be appreciated.
Re: Cam questions
You have a couple of choices: The off-the-shelf comp 212/218 cam would probably be fine. It seems to keep most of the low end power yet pull hard to the redline. It has low lift and easy ramps. OR Get a custom ground cam with faster ramps and more lift, but keep the duration numbers down. That will help you make more power and keep the torque strong. Get either cam on a 114 LSA and have 4* of advance ground in.
bbowerman
07-26-2015 10:57 PM
