Help 5.3 cam swap
Old 11-28-2015, 06:57 PM
elir_mn's Avatar
Default Help 5.3 cam swap
Hi, I want to make a cam swap my 2007 Silverado 5.3 (LY5), I have two options, Ls2 or Ls3 stock cam.
I recommend you, with which would have better profit?
Old 12-01-2015, 01:41 AM
04chevy2500's Avatar
They're practically the same cam
Old 12-01-2015, 01:48 PM
GM1697's Avatar
Neither are worth the time and effort.
Old 12-03-2015, 03:55 PM
Banned
thompson's Avatar
Like others have mentioned the gains wouldn't be worth the effort or time. There are plenty other great options out there to choose from.
Thanks,
Aaron @ Thompson Motorsports
Old 12-03-2015, 04:21 PM
zblee's Avatar
he mentioned he only has two options. of those two options, as it was already stated, they are basically the same. go with which one is cheaper or in better condition and that should be your deciding factor since specs are nearly identical. I think the ls3 has more lift (+.01) than the ls2
Old 12-03-2015, 06:54 PM
elir_mn's Avatar
Thank you for understanding
Old 12-03-2015, 07:07 PM
elir_mn's Avatar
Thanks for your opinion, I'm looking for my doubts, I understand what you mean but in this article speak say that despite the LS3 has more lift on the intake, the LS2 is a better option because it produces more torque
LS Cam Test Comparison - Car Craft Magazine
Old 12-03-2015, 07:12 PM
Vortec350ss's Avatar
The LS2 cam has a tighter LSA making the valve events slightly more ideal for a relatively small 5.3.
If you have to choose one or the other the LS2 will perform better.
Also worth noting... I dont think the LS3 cam has the cam sensor in the back where as some LS2 cams may.
Old 12-03-2015, 07:20 PM
zblee's Avatar
good find - looks like I was wrong about the lift amounts as well
Old 12-03-2015, 07:47 PM
elir_mn's Avatar
It must be because the cam LS2 has a degree less than LSA
Quick Reply: Help 5.3 cam swap
