engine vibration
Old 10-18-2006, 12:21 PM
sinistern2o's Avatar
Default engine vibration
got a 06 sierra 5.3 has a engine vibration at idle - 1,000 rpm .
only have 5,900 mile on the truck and the dealer say's nothings wrong.
any one else having a issue with engine vibrations ?
Old 10-18-2006, 01:04 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
Your Idle is at 1000 rpm's????? Should be like 600 from the factory. Yes, a shimmer at idle seems to be 'normal', mine did it too, untill i got it tuned.
Oh, i see you mean idle to 1000rpms. Mine would go away as soon as the rpms came up ober 800 or so.
Old 10-18-2006, 01:11 PM
mine's more than a shimmer , shakes pretty good then smooths out at around 1,100
Old 10-18-2006, 01:49 PM
trever1t's Avatar
Check your plugs/wires?
Old 10-18-2006, 02:12 PM
well I know sometimes new parts are bad but I would think
if it was plugs or plug wires it would set a code for a misfire .
I'm not getting a CHECK ENGINE light or any codes
1bad2k
08-18-2015 09:50 PM
DrX
08-11-2015 07:25 AM
vipergtrdj
08-06-2015 10:19 PM
V-seriesTech
07-28-2015 12:31 PM
bgray
07-23-2015 10:56 AM
Quick Reply: engine vibration
